Previous in Forum: Measuring Pipe Line Vibrations   Next in Forum: Temperature Measurement for Ice in Indoor Skating Rink
Manual Pressure-Reducing Valve
08/20/2009 3:26 AM
kindly requested to answer for this subject:
possibility of using one reducing valve IP:10 BAR and OP:1 TO 7 BAR
for changing the fuel pressure with below specification:
IP:1.7 OP:1.1
Re: manual pressure reducing valve
08/20/2009 3:42 AM
The question is incomplete. What fuel? - Pulverised coal, for example? And what about the valve - no line size information, no flowrate - just what is the question?
08/20/2009 6:55 AM
the fuel is diesel oil and using with 2 inch inlet for turbine system.
head of tank is on top of the turbine system and we want to reduced the head presuure of 1.7 to 1.1 with this equipment
thanks
08/20/2009 7:33 AM
Google "2 inch liquid pressure reducing valves" and select the compatible materials from a materials compatibility database.
08/20/2009 9:01 AM
Yes, You can use one reducing valve IP: 10 Bar and OP: 1 TO 7 Bar, but before You specify get the process information like fluid, temperature, etc.
08/20/2009 7:37 PM
Hello Salvaterra,
Welcome to CR4. You have obviously been observing it, before you made your first post.
Lyn
08/21/2009 7:22 AM
Hello Lyn,
Thank you so much. I have been observing it and I hope I can help and learn in the same time with the group of people of CR4.
Salvaterra
Anonymous Poster (1); lyn (1); PWSlack (2); Salvaterra (2)
You might be interested in: IP Cores, NEMA and IP Enclosures, VoIP and IP Telephony
