Previous in Forum: Life Assesment Procedure for Casr Resin dry Type Transformer   Next in Forum: single line diagram
Type of cable selection Between Transformer and NGR
08/26/2009 1:36 AM
Hi
Kindly be informed that i have 11kV/3.3kV 7.2 MVA transformer having NGR 100 OHM risistor,Require size and Insulation class of cable between Transformer star point to NGR risistor.Please provide referance and calculation as wel
Best regards
Abdullah
Re: Type of cable selection Between Transformer and NGR
08/26/2009 3:06 AM
It can be found in the transformer manufacturer's manual for the equipment.
08/26/2009 5:46 PM
Sorry, not without a purchase order and much more information. If I am going to be doing your job for you I expect to be payed.
If you are having a problem try looking at the technical documentation available or try a consultant (the answer is based on simple electrical theory coupled with set requirements listed in local electrical standards and regulations, all of which you should know if you are performing this design).
08/26/2009 11:30 PM
Why make life difficult. Get some electrical consultants to do the job.
Register to Reply 3 comments
jack of all trades (1); PWSlack (1); Simon Wan (1)
