Previous in Forum: Thermostatic Mixing Valve   Next in Forum: Air Compressors
16 comments
API 5L Grade B Pipe Equivalent Fitting Materials
08/26/2009 7:34 AM
Iam a constuction engineer in mechanical. Now i have been asked to select the materials for a small skid.
the pipe used in the skid is API 5L Gr B sch 40 Pipes , Pressure class of the system is #300. I have to select many elbows , flanges, Tees etc . What should be the grade of these Fitting Materials. Does the Fittings comes in A106 Gr.B .all the fittings are butt welded. any help please.
Re: API 5L Grade B Pipe Equivalent Fitting Materials
08/26/2009 8:20 AM
What's in the pipe, its temperature and pressure?
Good Answers: 243
08/26/2009 10:12 PM
The way I was reading this, its a mechanical only, "skid or pallet" not a pressure fluid containing device. milo
08/29/2009 1:13 AM
Milo, The Scope of the Project :Hot Tapping a Branch connection of 10" from a 48 " Existing Natural Gas Pipeline. The new 10" Pipe is going to feed a Steel company and for this the pressue needs to reduced from the present 45 bar. For the pressure to be reduced we are making a skid.( a 10mlong X 3m wide)piping arrangement which has valves and other fittings.the Inlet of the skid will have a 45 bar pressure and the outlet of the this skid the product will have a pressure of under 10 bar. Hope you understand what it means when i said a skid.??!!!
08/27/2009 12:00 AM
• The fittings schedule shall be the same schedule as the pipe, Sch. 40.
• Material of buttwelded fittings (elbows, reducers, tees, ... etc.) shall be : ASTM A234 Grade WPB (and its specification shall be: NPS ..., Sch.40, BW).
• Material of flanges, flanged fittings, couplings, ... etc. shall be : ASTM A105 (and its specification shall be: NPS ..., WNRF, Sch.40, 300#).
• The specification ASTM A106 Grade B is to specify a pipe (equivalent to pipe material API 5L Grade B), and the fittings shall not be specified with that specification.
Hobbies - DIY Welding - pipewelder
08/27/2009 10:15 AM
As usual a very good answer my friend and you get my GA. This is what I would call standard carbon steel fittings and seamless pipe. It is very common to use this grade of pipe and fittings on steam as well as other services such as 150 lb. steam, hot mill water, and condensate, or at least it is in my area. If this pipe was used on the condensate return side of a same PSI rated steam line we would go to Sch.. 80 on anything below 8" NPS pipe to compensate for the extra wear. This material is what most pipe suppliers keep in stock and is readily available and I consider the pipe as one notch better than SA 53 ERW pipe.
pipewelder
08/29/2009 1:18 AM
Sir,
it is found that ASTM A234 has grade WPB (Butt welded Fittings ) but Flange materials A105 has no grade specified. Why is it so?
Also what factors are needed to consider when we weld materials of different grades. What is the compatability?
Thanks in Advance.
jinson
08/29/2009 3:13 AM
All materials API 5L, A234-WPB, A105 & A106-B are carbon steel materials, and are compatible and have the same weldability and closest of their carbon equivalent. So you can use filler metals for SMAW welding of these materials such as E6010, E7010, E7010G & E7018.
No way to weld a materials with a different weldability. I mean no way to weld carbon steel pipe material A106-B with flanges of alloy steel of high temperature service A182-F11 (1.25 Cr-0.5 Mo). Where you have to use a carbon steel flange A105 to be welded with pipe A106-B.
Important note. May be you can find a different materials with different grades but they have the same weldability. In the same time, you can find one material with different grades, but no weldability found between these grades.
For example the material of butt welding fittings A234 have a lot of grades, such as WPB which considered a carbon steel grade with C % 0.30 max. & Cr % 0.4 max. and grade WPB9 which is considered an alloy steel grade with C % 0.15 max. & Cr % 8-10 for higher temperature services, and no weldability found between those grades.
09/15/2010 2:33 PM
DEAR GENTELMAN !
CAN WE USE ASTM A106 GRADE B INSTEAD OF API 5L GRADE B. ?
REGARDS,
MANSINGH
09/15/2010 10:48 PM
Yes, you can use ASTM A106 Grade B instead of API 5L Grade B. But vice versa is not correct in many cases, like the tubes at fired heaters, where we can use A106 Grade B, under the same condition we can't use API 5L Grade B instead of it.
09/17/2010 2:04 PM
The following article is extracted from Paragraph 5.3.5 of API 570-2009 "Piping Inspection Code -Inservice Inspection, Rating, Repair, and Alteration of Piping Systems", which indicates the difference in use of API 5L and A 106:
"Note that nonsilicon killed steel pipe, such as A-53 and API 5L, may corrode at higher rates than does silicon killed steel pipe, such as A-106, especially in high-temperature sulfidic environments".
09/01/2009 1:37 AM
Dear Sir/Madam,
I request you to please Visit My Website :- www.khyatihydraulics.com and Download all my Catalogs I'm sure my SAE flanges, Low and High Pressure Hydraulic Valves, Hydraulic Accessories, Hydraulic Equipments, Seamless and ERW Pipes, and Hydraulic Fittings and Forged Fitting Catalogs will be useful to you. Please Sent me Your Exact Requirements with Specified Standards so that i can Sent you a Complete offer at Most Competitive Price. we are, in the Hydraulics since last 32 Years.My Email ID is sales@khyatihydraulics.com. I'm sure that i'll be able to help to out if you have any problem associated with the feild that i'm purssuing.
Thanks and Regards,
Chintan Padia
Manager Marketing and Sales
Mobile :- +919870000820
09/04/2009 1:11 PM
Hi all,
I've tried to check www.khyatihydraulikcs.com it looks to be infected or better saying a trojan alert shows up.
Please check this to avoid any mess...
regards,
valveman
09/05/2009 2:31 AM
Yes, you are right, the site www.khyatihydraulics.com includes a Trojan virus, and I recommend that CR4 administrator to delete the post like as his many posts deleted 2 weeks ago for the same Gust "Chintan Padia Manager Marketing and Sales" who do his best announcing and advertising for his products.
10/04/2009 10:04 PM
I'm a civil engineer but I want to learn.
Which code we can check for selection of this suitable fitting spec? How about A106B and P22 pipe? What is the correct spec for the fitting?
02/17/2014 1:34 PM
Dear all,
What about ASTM A 53 type E Grade B?
Can I use it interchangeably without differences from API 5L - PS-1 - GR B?
The fluid is cooling water at room temperature.
What are the differences between ASTM A 53 and API 5L?
Thank you.
01/05/2016 11:16 PM
Dear All,
could you please advise the engineering practice for fitting material selection that compatible with high strength carbon steel pipe API 5L (ex. API 5L X65)?
A860 material come in mind, but actually I have use A694 as my fitting material before (reducer in pig trap)
is there another high pressure carbon steel material that can be used?
on another note, is there an ASME material for fitting and flange that have high yield strength equal to or more than 65000 psi (or close to it)?
Register to Reply 16 comments
9one (1); Abdel Halim Galala (5); Anonymous Poster (3); brunosilvanjos (1); budi_satrijo (1); jinsonmc2004 (2); Milo (1); pipewelder (1); PWSlack (1)
You might be interested in: Hose Fittings, Tube Fittings, Gas Fittings
