Previous in Forum: Painting for Hot Surface 90 Degree Celcius   Next in Forum: Pollution
Design of heat exchanger
08/28/2009 3:13 AM
can you guide me? my procedure is correct or not
1.Q=m cp dT
2.m1 cp1 dT =m2 cp2 dT
3.Finding U(h) AND ^T
4.A= Q/ U*^T
For finding no.of tubes
5. Flow rate = AREA* VELOCITY
by assumption, average velocity =0.9 m/sec....... will find area.
6.for 5/8 OD i will get no.of tubes n*pi*d2/4 = area
For finding length,
7. surface area = 2*pi*r*h* n
will find h value- length of the tube...
for reducing length i will use correction factor in area formula.
THEN will continue MECHANICAL DESIGN.
HERE I have doubt in
1. HOW TO ASSUME VELOCITY FOR PROPER HEAT TRANSFER.
2.PRESSURE DROP IN CALCULATION AND EFFECTIVE LENGTH OF HEAT EXCHANGER...
3.ANY OTHER METHOD FOR THERMAL DESIGN...
4.FINDING SHELL SIDE HEAT TRANSFER COEFFICIENT...
Re: Design of heat exchanger
08/28/2009 6:41 AM
<...2.PRESSURE DROP IN CALCULATION AND EFFECTIVE LENGTH OF HEAT EXCHANGER...>
Use the Weisbach-Darcy equation for generalised pipe flow.
<...3.ANY OTHER METHOD FOR THERMAL DESIGN...>
Use the log-mean temperature difference rather than the arithmetic mean.
08/28/2009 9:10 AM
Thank you sir
is my approch correct or not for NO.OF TUBES AND LENGTH OF THE TUBES
Register to Reply 2 comments
