Previous in Forum: Charging a 220-KV Line at 33-KV   Next in Forum: Faults in 132-KV Transmission Lines
Surge Arrester
09/01/2009 9:52 AM
Hello everyone.I have a doubt regarding surge arrester.The surge arrester in switchyard is copnnected with rthe incoming line and it is always in open ckt. condition.For 220kv system the phase to neutral voltage is 127kv.
Why the rated voltage of surge arrester for 245(max.) system is 198kv and maximum operating voltage is 168kv?
9max.)
partha sarathi pattanaik
Good Answers: 27
Re: Surge Arrester
09/01/2009 11:16 PM
Although you don't define define the type of station class arrester, it is not an open circuit because regardless of construction, a grading current flows through the arrester as long as it is connected between line and ground. If it is a gapped type silicon carbide, grading current flows through the grading circuit and if gapless, grading current flows through the metal oxide varistors (MOV). The arrester rating may be based on the maximum phase to ground operating voltage (probably assuming 10% regulation), the maximum temporary overvoltage that can exist at that location, system grounding, etc.
Remember, surge arresters are designed to protect against impulse overvoltages not power frequency overvoltages. They have a TOV rating which is essentially a volt-time curve that defines the magnitude and duration of power frequency voltage above their maximum continuous operating voltage (MCOV) they can be expected to survive without damage.
