I know how to build a PWM circuit to drive a MOSFET which switches a coil step-up type 12T to 80T small miniature core to wind your own transformer to generate high voltage! Hard to find I searched the web and found the exact part but it is obsolete! The one I want was used in a DIY circuit. It is obsolete now with no replacement. The core was part number ETD29-3C90 made by ON. I would like to get some equivalent part to this otherwise you have to buy 250 min. from the web searches I have done. I just want a few!
I need about 250VDC 25ma would be nice to drive (2) plates of a 12AX7 using 12.6VDC input regulated which would take care of the heater. What about the stomp Fuzz 12AX7 pedals they must use a circuit like this using CEMF and storing it? Any suggestions? The 12AX7 will be Cathode biased no negative voltage needed. I also can drop the plate Voltage a bit as long as I can overdrive Class A1.
