I've been handed the task of seeing what I can do to improve the combustion of a 35-year old "Dutch Oven" hot water generator. The system is fired with dry wood shavings, screw auger fed to the underside of the fuel pile in the Dutch oven.
The combustion chamber is a square box, about 8 feet square, with a low ceiling, in the range of 5 feet. The combustion is fed air from over-and underfire pipes 3" in diameter. The hot gases pass over a bullnose and travel under the suspended boiler, travelling back through the single pass boiler tubes in a "Horizontal Return Tube" (HRT) configuration. The gases pass through a multicyclone on their way to the ID fan and up a tall stack.
The problem that I need to address is twofold: (1) Particulate emission from this system is quite high--in the range of 215 mg/m3, where our permit level is 230. To achieve the 215 in test conditions, everything has to be just perfect with the system. (2) Premature firebox wear--we need to replace the refactory every year because it tends to disintegrate from what we believe to be very high temperatures. A third item that I would like to address is the possibility of getting a little extra energy out of the boiler by ensuring that the hottest possible gases pass through the boiler tubes.
I'm thinking that a better combustor design for shavings might be a round firebox with the forced draft being tangential (cyclonic) to ensure maximum burning time. In addition, the firebox might be better to be significantly taller than its horizontal dimensions to reduce refractory problems.
Suggestions and comments would be much appreciated. Does anyone know of any books or websites that might help my understanding of the issue?
Thanks, Jon.
