Previous in Forum: Measurement of Coupling Resistance   Next in Forum: Electrical Engineering
Armature Loading
09/04/2009 6:27 AM
I have a armeture of 5kw loading capacity & i want to give the load of 10kw is it possible, if yes then how.Which type of ckt or transformer is used please giving me the solution.
Re: Armeture
09/04/2009 6:37 AM
For how long before it burns out, please?
Drop back to basics: what is this thing installed to do?
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Armeture
09/04/2009 7:43 AM
OK...Now that you have the Armature out of the frame, here's what you need to do...
1) Carefully press the shaft out of the laminations.
2) Find laminations big enough to handle the new rotor bars
3) ReCast the Rotor bars and shorting rings
4) Get the rebuilt Armature carfully balanced
5) Now go and get the Frame and Stator, these can now be rebuilt to match the Armature..
On Second thoughts, apply reality and go and buy a 10kW Motor off the shelf.
Regards,
Sapper.
It's all about the Boom! - MythBusters
Re: Armeture
09/04/2009 8:14 AM
....and upgrade the supply wiring and protection devices to match it before switching it on.
Re: Armeture
09/05/2009 11:43 AM
another innovative trial may be made....
pour the high voiltage resin in the existing armature winding, up grade the voltage level from 220 v to 440 v or 414v to 800 v, replace the bearing of higher caPACITY TOO.
Exploring the Science of Electricity
Register to Reply 4 comments
harry potter (1); PWSlack (2); Sapper (1)
You might be interested in: Loading Arms, Motor Coils, DC Servomotors
