Previous in Forum: Ingredient in glue pest   Next in Forum: cooling tower
SOFTENING OF POLYURETHANE FOAM
09/07/2009 1:39 AM
WE USE POLYURETHANE FOAM FOR INSULATION IN REFRIGERATOR.
CHEMICAL USED IS : ELASTOPOR MH 1031 C-A (4,4 DIPHENYLMETHANE DIISOCYANATE(MDI)
: LUPRANAT M20 S (POLYOL)
: CYCLO PENTANE(BLOWING AGENT)
SOMETIMES SHAPE OF OUTER BODY OF THE REFRIGERATOR BECOMES IRREGULAR DUE TO NON UNIFORM FLOW OF THE ABOVE FOAMING CHEMICALS.
IS THERE ANY SOLUTION TO SOFTEN THE RIGID FOAM FOR REMOVING FROM THE REJECTED CABINETS.
Re: SOFTENING OF POLYURETHANE FOAM
09/07/2009 3:22 AM
Methylene chloride. Methyl ethyl ketone. Hexafluoroacetone sesquihydrate.
Electric carving knife.
Good Answers: 120
09/07/2009 10:41 PM
You need to foam the cavity with an inner and outer lining, so that nothing can make bumps on the surface. Then the urethane must be a little slower curing, so it stays more flexible and flows into all the crevices and is a uniform foam.
A friend of mine makes fridges this way. The inner lining and outer shell are foamed en-situ with removable bracing.
Rapid refrigeration.
http://www.rapidfridge.com/home.html
Per Ardua Ad Astra
Good Answers: 42
09/08/2009 3:08 AM
Try solvents like ethyl / butyl acetate[ ester solvents], ketone based solvents like MEK OR ACETONE , using a pad or fabric to soak out the hard resin solublize it and remove by gentle scratching.
Nature is so graceful and naked. Human possession is ridiculous.
09/08/2009 8:42 AM
As a urethane molder my favorite chemicals for removing unwanted resin are from http://www.dynaloy.com/Products/urethane_products.html Dynaloy.
Register to Reply 4 comments
aurizon (1); Daddio926 (1); lyn (1); s.udhayamarthandan (1)
