Previous in Forum: SOFTENING OF POLYURETHANE FOAM   Next in Forum: How to De-Ink Paper
8 comments
cooling tower
09/07/2009 1:54 PM
if a hyperbolic cooling tower turns into cylinderical cooling tower of lesser height than former then how can we increase the efficiency of this cylinderical cooling tower
Re: cooling tower
09/07/2009 3:18 PM
Stretch it back again.
Good Answers: 143
Re: cooling tower
09/07/2009 4:30 PM
We're not gonna give you another cooling tower until you explain how you broke this one.
Are you a cooling tower designer, or are you doing homework? Any road, here's a site that helps students with cooling tower questions.
Good Answers: 54
Re: cooling tower
09/08/2009 1:18 AM
Add a fan to push more air through it
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 50
Re: cooling tower
09/08/2009 4:17 AM
Make it bigger around.
Re: cooling tower
09/08/2009 6:12 AM
Add a VSD and 1 or 2 of the following:
spray pump
damper w/ actuator that is proportional to temperature
or all 3, but you must not interfere w/ motor windings or cause misting/ flow pattern that would make existing air flow pattern inefficient.
Re: cooling tower
09/08/2009 9:17 AM
Hi..
"if a hyperbolic cooling tower turns into cylinderical cooling tower of lesser height" What do you mean by lesser height. Today a 25000Cum/hr normal flow cooling tower for a 210MW coal fired power station is about 120 meter height. Similarly a 500MW Nuclear power station will need a 100000Cum/hr capacity cooling tower of 165 meter height. What heights are you speaking of?
It is the hyperbolic shape which induces the natural draught. No energy is expended to run them although quite a bit is consumed in building these monsters.
During the initial years there were short height cylinderical cooling towers which were of forced draught design i.e. you had to pump air through the bottom part of the cylinder in order to create the draught. These were later discarded as more efficient induced draught cooling towers were developed & natural draught cooling tower construction took off properly.
Anil Tiwari
Re: cooling tower
10/26/2010 6:15 AM
why not check out www.coolingtowers.co.za and they will be able to assist you with all queries
Re: cooling tower
09/09/2009 6:40 AM
Add packing to the tower so as to increase mass transfer rates.
Register to Reply 8 comments
aniltiwari (1); Anonymous Poster (1); DRFREON (1); ffej (1); PWSlack (1); TVP45 (1); vermin (1); Whitfield (1)
