Previous in Forum: Use of MS bolt and SS bolt   Next in Forum: Automatic Repositioning 360° Swivel Ball / Bearing
Counterbalance Valves vs. Brake Valves
09/07/2009 7:33 PM
The internal spools in a counterbalance valve and a brake valve are different.What is the main physical difference between the two spools
Re: counterbalance and brake valves
09/07/2009 7:51 PM
Counter balance valve
Brake valve:
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: Counterbalance Valves vs. Brake Valves
09/08/2009 10:59 PM
Hi Mark
I'm not quite sure if my answer to this is what you are looking for, however, the two types of valves are completely different and perform different functions.
A brake valve is a modulating valve and (hydraulically) allows flow in both directions (of which, one direction is 'power assist').
A counterbalance valve is a load hold valve with free flow in one direction and controlled flow (subject to pilot through variable relief) in the opposite direction.
Both valves have many different variants!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
09/09/2009 10:02 AM
A brake valve will supply oil to a brake.
A counter is limiting flow so the oil is applied to the counter, thus is subject to system changes like cavitation that may render the valve useless in certain situations if used as a brake valve. Not Safe.
05/22/2019 3:45 AM
The function of brake valve is same as counterbalance valve. The key difference is the pressure drop across the counter balance valve is convertted in to heat. Due to this a large amount of hydraulic power wasted and the brake valve is used to avoid this disadvantage.
Register to Reply 4 comments
Anonymous Poster (1); Beej50 (1); lyn (1); Preetha (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
