Previous in Forum: How to Strengthen Tubing Mechanically   Next in Forum: Deflection at CG or Reed (Natural) Frequency of Motor
How to Select a Dust Collector
09/09/2009 3:35 AM
i need to select a dust collector for grinding purpose. hand grinder is used for this work and the disk size is 4". what are the information that i need to select a suitable dust collector.
Re: how to select a dust collector
09/09/2009 7:16 AM
The volume of dust to be collected would be a useful number to have, as would the servicing frequency for the collected dust, the voltage and frequency of the supply, etc.
09/09/2009 3:48 PM
Additional information needed also includes
- How fine the dust particles are? Is the dust in a form of very sharp splinters requiring a special storage system, does it react with the atmosphere to form a sticky that cold clog dust extraction equipment, etc
- What is/are the material(s) you are grinding is (is it environmentally hazardous, potentially explosive requiring hazardous-area rating considerations, conductive, etc)?
- Does the dust require special storage and/or disposal due to local environmental regulations?
- Does the collector need to be portable? Is this for a fixed machine or someone holding a hand-tool? Is the person at a fixed station area or is he/she moving around while grinding?
- How good does the extraction system need to be? Are you after a basic level of extraction to minimise mess (such as woodworking), are you extracting the dust to also protect workers (dust is a eye/nose/throat irritant), do you need an extraction system good enough to collect all the dust due to serious safety issues with the dust (dust is harmful to personnel/environment/explosive/toxic, etc)? etc.
As you can see much more information is needed. Please provide what you can, or at the very least a detailed explanation on exactly what you are doing/wanting to do.
09/09/2009 10:11 PM
the material is cast iron. grinding is done to final the product. the operators are not moving. . but SPM level is higher than recommend because of there is no dust collector. recommend is 0.05mg/m3 and exists level is 1.6 mg/m3. this area is not close. its an open place. so i fabricate a grinding booth for each operator. there are four operators doing it.
but a dust extractor is need to lower the dust level. i like to know how we select a dust extractor or the flow rate to reduce the SPM leve from 1.6 to 0.05. please tell me the procedure to calculate the suitable flowrate for the exhaust system.
09/16/2009 9:05 PM
For an application like this I would advise talking with a local air/dust extraction sales company. Tell them your needs and they should be able to offer you the parts for a suitable extraction fan system or supply you a complete solution.
09/09/2009 4:05 PM
Forgot to mention also, are you wanting to extract and vent the dust outside or do you need to vent it to a storage container (eg- will a wall-mounted extractor fan do or do you need a device like a vacuum cleaner)?
jack of all trades (3); PWSlack (1); ruchiraslk (1)
