Previous in Forum: Current Carrying Capacity   Next in Forum: Measuring Current from an AA Cell
High DC Current Measurement
09/09/2009 10:49 PM
well can some one tell me how the d.c current measured in high current d.c circuits.....??????????there is 690volts 1mw d.c motor in our mill house but how to measure current as tounge tester dosent measures d.c current.
tarang
Re: high d.c current measurement
09/09/2009 11:43 PM
Standard clamp meters only measure AC current. You need either a clamp meter designed for DC current or a current shunt.
The following is a suitable example 2000A AC/DC clamp meter
http://www.extech.com/instruments/product.asp?catid=26&prodid=90
also google "dc current clamp meter" for plenty more.
A current shunt at 1450A DC is going to be expensive but is a possibility.
http://en.wikipedia.org/wiki/Shunt_(electrical)
I would go with a suitable DC clamp meter for your application unless you cannot physically get the clamp head around the motor wiring or bus-work anywhere (even then you should be able to find a DC clamp meter with extra-wide jaws).
Re: High DC Current Measurement
09/10/2009 1:01 AM
All DC motor used DC speed drives to control the motor. In your speed drive unit it is already design the output for the DC current to be connect to the DC current indicator for the display of the DC current.
There is AC/DC tong tester available in the market and you can use it to check our DC current of your DC Motor. It not expensive.
Register to Reply 2 comments
You might be interested in: Current Sense Amplifiers, Current Transformers
