Previous in Forum: Vortex Problems in Pump Applications   Next in Forum: CEP TRIPS
9 comments
Flow and Pressure Through Stand-By Centrifugal Pump
09/11/2009 3:07 AM
Two centrifugal pump installed in parallel (1w+ 1sb) for cooling water application to boost pressure. At the inlet of pump pressure available is 3.3 bar(a) and after after boosting i.e at outlet of pump, pressure became 7.7 bar(a). My question is : what will be pressure & flow at the out let of stand by pump just before check valve installed at the outlet of pumps ?
Good Answers: 58
Re: Flow & pressure through stand-by centrifugal pump.
09/11/2009 3:49 AM
Suction pressure and no flow. TGIF
09/11/2009 4:28 AM
Guest : Original Poster.
Does it mean, centrifugal pump may be considered similar to reduced bore pipe. And if test valve, which is before check valve,to be opened shall dischrge water approximately at suction pressure level of pump and flow corresponding to test valve opening cross-section.
Good day.
Good Answers: 137
09/15/2009 11:43 AM
The Prof's answer told you everything you need to know to answer your original question. If there's a test valve, that makes a difference. Why didn't you say so before?
Codey
Re: Flow & Pressure Through Stand-By Centrifugal Pump
09/11/2009 11:57 AM
Refer to the manufacturer's performance graphs for this particular pump.
Re: Flow and Pressure Through Stand-By Centrifugal Pump
09/11/2009 9:47 PM
excuse for my ignorance. Im still learning english and Im studing engeenering but i can not find the relationship between the words to undertand what do you mean with a "Stand by pump" can you please tell me where can i find information about it. Thank you very much!!!
09/12/2009 2:29 AM
Usually in continuous operations we provide standby systems. Systems are programmed in such a way that after certain period of running the pump the system will over to other pump. This is the meaning of standby. In some applications standby system are provided to carry out the maintenance of the other equipment without disturbing the system operation.
09/12/2009 12:36 AM
Hi
I have gone through your question, I would like to correct you here. Parallel operation is to boost the flow not the pressure. If the sandby pump is working alone , then it is like a normal pump. If both the pumps runs in parallel, the head and flow will get shifted depending upon the system resistance. To find out the exact point , draw a parallel operation curve along with system resistance curve. The intersection point of these two curve will give you the new duty point.
Hope this will Help.
09/12/2009 7:27 AM
If the suction valve is closed and the discharge valve is open, the fluid passing thro check valve/NRV (these are not leak proof), will build up discharge pressure up to the suction isolation valve. Some suction lines are damaged due to the lack of consideration of this aspect.
09/14/2009 2:44 AM
Agree with b v rao. "Ideally", if the check valve is not leaking the test valve will only see the suction pressure. But in many cases, the check valve is not fully isolating, and therefore the pump can see high pressure.
If the suction valve is also open this will lead to reverse flow (which is damaging to the pump is not designed for reverse flow). If the suction valve is closed, then there could be a high pressure scenario. I will be careful before opening the test valve particularly for high pressure pumps, even if it is upstream of the check valve. Consider providing a thermal relief valve between the suction valve and the check valve!
Continuous Learning
Anonymous Poster (3); b v rao (1); Codemaster (1); mrswamy (1); PWSlack (1); sv13 (1); The Prof (1)
You might be interested in: Pressure Intensifiers, Hydraulic Pumps
