Previous in Forum: Flow and Pressure Through Stand-By Centrifugal Pump   Next in Forum: How to read Vernier calipers?
Location: MELPALLIPATTU,CHENGAM,THIRUVANNAMALAI.TAMILNADU,INDIA,606703.
CEP TRIPS
09/11/2009 4:54 AM
If condensate extraction pumps(CEP) trips & steam turbine condenser vaccum moved to positive side pressure what will happen?
BALAJI JAYAKUMAR.
Re: CEP TRIPS
09/11/2009 11:56 AM
The thermal efficiency of the turbine system will fall, up to the point where it becomes backed-up with condensate. At that point, anything from a stalled turbine to catastrophic and irrevocable self-disassembly of parts or all of it may be expected.
Re: CEP TRIPS
04/26/2020 5:39 AM
Dear Mr. pjkbalaji,
If condensate extraction pumps(CEP) trips, what is needed is the stand-by condensate extraction pump should instantly start. If not, the condensate HIGH level protection system MUST trip the turbine.:
Otherwise:
1. The condensate level will build up further, fall in vaccuum (as you mentioned) will lead to more steam demand for the same power level of output, leading to vicious circle. Perhaps condensate may enter in to the rotor blade area
2. Water Hammering effect with in the condenser will develop severely.
3. Cause damage to the tubes in the condenser, and may get loosened from the tube plate
4. Severe Vibration of the Turbine Rotor will set in
5. May lead to catastropic disaster.
As an Engineer, operating the plant you donot even think like this.
DHAYANANDHAN.S
DHAYANANDHAN.S
Register to Reply 2 comments
