Previous in Forum: Neutral Current transformer   Next in Forum: induction motor
Support Standards for PVC Ducts Use in Gas&Oil Installations
09/12/2009 7:48 AM
Please colleagues:
Can you let me know, if there; the electrical standards that permit use underground concrete encased PVC electrical duct banks in Cl I Div I Group D for power, instrumentations and control?
Thanks in advance
Serca
know it's a treasure
APIX Pilot Plant Design Project - Member - New Member
Re: Support Standards for PVC Ducts Use in Gas&Oil Installations
09/12/2009 3:00 PM
Dear Serca,
PVC is a relatively good choice and does offer insulative nonconductive material for
the conductors of power or instrumentation and control, but in most cases you would
also have to consider the thermal effects of encasing the conductors in concrete which could cause some ark flash problems or amperage build up better backfilled
with gravel and top filled with sand and clay.
rwengin,
Design engineer
www.targetmartone.com
09/12/2009 3:14 PM
concrete encased PVC should be ok as long as the following conditions are met:
  1. The wires carrying power are large enough to keep heat build-up to a minimum.
  2. The PVC is large enough to permit easy pulling of wires; (long radius sweeps, no 90 or 45° turns).
  3. Wires are properly protected, entering and exiting the concrete.
Mr.Ron from South Ms.
Register to Reply 2 comments
