Previous in Forum: AI Bits and AO Bits   Next in Forum: Equipment for Measuring Turns?
UPS Power Backup calculations?
09/15/2009 12:22 AM
No. of Batteries: 10; Each Battery Capacity: 20V, 12 amp hr; 230Volts supply.
How can i calculate how much time it takes to discharge completely at o/p load of 10%.
Sunitha, Instrumentation
Re: UPS Power Backup calculations?
09/15/2009 4:59 PM
A google search of "UPS battery discharge calculation" produced a number of links to suitable calculation webpages and the formulas behind it (depending on how accurate you want the answer).
For example
http://www.solidstatecontrolsinc.com/techhpapers/pdfs/selectionsizingups.pdf
http://www.gizmology.net/batteries.htm
etc.
09/19/2009 12:04 AM
You have given 10 batteries and each battery is 20V/12amp hr. Total voltage is 230V.
And I presume that you connect your batteries in series connection. But in series connection the total voltage is 10 x 20V = 200V.
If you need to calculate how much time it takes to discharge completely at o/p load of 10% we need to know your total load. So what is your total load?
Asking a question like this, it is impossible for anybody tell you, how to calculate the time taken to discharge completely at o/p load of 10%. 10% of what?.
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
09/19/2009 6:15 PM
given that battery capacity 12amp/hr X 20 v =240watt /hr
10 batteries in parallel will give 2400 watts
10% of of the load is 240 watts so 2400/240 =10 hrs approximate to discharge completely
09/21/2009 10:29 AM
The original poster did not state the load on the batteries, therefore this calculation is not valid!
09/22/2009 9:01 AM
well what I thought that the battery capacity includes the battery load .offcourse I agree that some energy is lost across the battery which is constant but the battery specification do includes this losses .
regards
Adil
10/27/2009 10:19 AM
thanks
Register to Reply 6 comments
Anonymous Poster (1); find2am (2); jack of all trades (1); PWSlack (1); Simon Wan (1)
