Previous in Forum: Cheated by the Electric Company?   Next in Forum: Lightning Protection
12 comments
Where Does the +5V Rail Go?
09/18/2009 5:56 AM
can any1 explain where the +5v rail goes?
i know the 12v goes to pin 9 of the db9 which connects to pin 16 of the j1962
http://www.obddiag.net/allpro.html
Good Answers: 15
Re: Where Does the +5V Rail Go?
09/19/2009 1:47 AM
Are you asking which DB9 pin the +5V goes to? Doesn't. OBD-II only needs +12V from the vehicle system, so there isn't any need for a +5V line. Or are you asking something else?
09/19/2009 5:12 AM
this circuit shows +5v rails go to the website to have a clearer look
09/19/2009 4:53 AM
Diagram is (as usual) as good as unreadable on CR4. Do you have the possibility to post it on another page where anyone can look at it? Facebook for example.
09/19/2009 5:07 AM
ive given the website on the bottom
09/19/2009 8:23 AM
I have found the circuit diagram after searching around, it would have been most polite to have supplied the exact link.......
By the way, are you trying to build this without buying a kit? The kit would have the PCB and be correctly laid out for all the voltages used.....
I will assume that the USB cable supplies the 5 volts for all the chips.....this is fairly normal.
It is generally cheaper to buy a complete kit than to buy the individual components. In the kit will be a correctly made PCB too.
Good Answers: 12
09/23/2009 1:16 AM
The bottom of what?? I have yet to see a web site.
09/23/2009 6:25 AM
The bottom of the original post:-
09/19/2009 6:57 AM
Regards
The device is for 12 /24V systems as shown by the manufacturer so it semms that it is erroneousl marked +5V instead of +12V.
Good Answers: 16
09/20/2009 4:22 PM
The +5 volts is being supplied by the USB connector, J1. This is mentioned in the paragraph entitled HARDWARE in the link provided. The 12 volt source is generated onboard from the +5 volt power bus. I think this answers your question.
09/20/2009 4:33 PM
I said the same in my post #6 that the USB supplied the 5 volts......there was no 5 volt regulator on the PCB......was my method of finding that out.
09/21/2009 3:12 AM
I don't understand the question. The 5V supply comes from the USB connector shown in red and goes to several places shown in blue.
The 12V used on the board is taken from the vehicles battery via a signal diode connected to the DB9 pin 9.
Hobbies - Musician - Tube Amps Only Please!
10/26/2009 11:39 PM
I can't read this thing!
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 12 comments
Andy Germany (3); Electronic Wiz (1); Haajee (1); kaos91 (2); maveric_manic (1); Mitsurati (1); Randall (2); Sciesis2 (1)
You might be interested in: Rail Services, Height Gages, PIN Diodes
