Previous in Forum: double acting actuators   Next in Forum: Mass Flow Meter - Calibration and Commissioning
PID Fine Tuning Reg
09/19/2009 9:05 AM
Hello guys im new to this group.
I have some basic doubts about fine tuning PID loop what for Kp Ki Kd are used for tuning the pid loop and whats the function of those pl reply me..............
thirsty
Pathfinder Tags: PID
Re: PID fine tuning reg
09/19/2009 9:29 AM
Hello Kumaresnk:
I'm not sharp enough on tuning the PID's to be of much help, so I will be following this discussion with interest. I did find a link that may help you however, and I'll be practicing to sharpen my skills today.
http://www.engin.umich.edu/group/ctm/PID/PID.html#p
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
Good Answers: 119
Re: PID Fine Tuning Reg
09/19/2009 9:31 PM
You should be able to find all the answers to your questions if you read
http://en.wikipedia.org/wiki/PID_controller
Auto-tuning PID controllers are preferred with systems that have LONG time constants (typically thermal). Otherwise you will be tuning manually for DAYS. Been there, done that, never again!
South Africa - Member -
Good Answers: 12
09/28/2009 1:42 AM
Hi there,
I don't think you should be tuning any loops.
Kp - Proportional action
Ki - Integral action
Kd - Derivative action.
You need to supply much more information on your controller type. We would need to know if the controller is an ideal, series or parallel algorithm? Is the proportional action really proportional or is it actually gain?
Is the integral action measured in repeats per second or seconds per repeat.
As you can see - loop tuning is not something that can just be taught over the net. I suggest you have a look at some of the case studies on this web site. It might give you a better understanding.
www.controlloop.co.za
Regards,
Craig
Register to Reply 3 comments
craigza (1); mjb1962853 (1); YWROADRUNNER (1)
