Previous in Forum: Can You Use a MIG or CIG Welder to Weld Aluminium to Steel?   Next in Forum: stepper motor
Wall Thickness Calculation - ASME B31.3
09/20/2009 12:18 AM
Couly you anyone explain me about the significant of 'Y' - co efficient from table 304.1.1 in wall thickness calculation as per B31.3. why this to be considered and reason behind that?
Thanks,
Uthayasankar.
Re: Wall Thickness Calculation - ASME B31.3
09/29/2009 3:27 AM
Ok, I will explain something for you, the coefficient Y is used in eq (3a) or (3b) in ASME B31.3 (304.1.2) is wall thicness coefficient.
It is hard to find a t (thicknesses) > D/6 in standard pipes, so choose value of Y from the mentioned table (304.1.1)
may be and I am not sure, there is a smaller pipe size has t>D/6 and it is rarely.
Regards
10/02/2009 4:16 AM
Naif, t will easily exceed D/6 when comes to high pressure small bore piping/tubing. I have a hydraulic system where I need to design the tubing/piping to withstand 10,000psi. I found a book that suggest using chapter IX of b31.3 but the problem is a790 is not listed. Still struggling to get a solution...
Regards,
htl
10/04/2009 1:21 PM
Ok, could u please tell us where u need a 10,000 psi with small diameter?
cause this is first time i heared about small dia. with t>D/6
regards
10/04/2009 9:22 PM
hydraulic lines for control systems! FYI, all pipe less than or equal 3" with sch xxs in asme b36.10 actually has t>D/6.
regards,
htl
05/19/2011 6:18 AM
Hi there,
If the material is not listed in Table A-1 then a prudent approach is to look up the stresses in the material standard or globalspec etc. Use the lower of two thirds yield or one third tensile for your allowable stress.
04/04/2012 3:45 AM
wall thickness calculation as per B31.3 is minimun thickness?
please anybody tell me about base condition for wall thickness calculation for PMS,...
for example in PMS ,I see that thickness is 15 mm for 52 inch pipe but according to asme code calculaton it is about 9.5 mm...
withch one is correct, please advice me...
04/15/2012 8:40 PM
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Angus (1); Anonymous Poster (2); jackchen (1); Naif (2); sasan330 (1)
