Previous in Forum: Wiring UPS-Connected Appliances   Next in Forum: Dynamic Breaking in Hydro Generators
10 comments
Electrical Conduit Through Concrete Floor
09/21/2009 12:10 AM
Your helpful comments would be appreciated here:
I need to run future wiring through a concrete slab floor. The floor above will be a greenhouse on the second floor. We will pour 6" of concrete. I've set four 1" sched, 40 PVC electrical conduit in place to handle the future wiring, anticipated to be about 6000 W, 120 V. The conduit extends about 18" above the concrete floor.
Is this a good plan. I was considering using a 3" PVC drain sleeve, but was worried that it would violate the building code, so I chose 4 x 1" PVC conduit. Is the combustibility of PVC a problem?
Thank-you in advance.
Re: Electrical Conduit Through Concrete Floor
09/21/2009 8:10 AM
Local codes are different. Consult your local government agency that will handle the inspection and ask them.
Or, at least tell your location.
Good Answers: 114
09/21/2009 8:38 AM
I don't know where you are, but I am alarmed that you ask the question, an elevated reinforced concrete floor needs the attention of a qualified, licensed, engineer.
If I was doing this, I would look at using cellular metal deck or a mix including some cellular. It is a stay in place formwork and, if you use a composite deck you might be able to use less concrete and only a small amount of shrinkage reinforcement. It is used in many office and industrial buildings to allow future uses different to the original design.
A 3" cellular deck is shown http://www.dek-ing.com/dekfloor-n2418cellcomposite.html
09/21/2009 11:44 AM
Please don't be alarmed. The floor has been designed by a civil engineer and it's my own home. Here in Ontario, Canada, homeowners can install their own electrics. From my limited understanding of the Ontario building code, it says 1" max for combustible raceways to maintain "fire separation" On the other hand being a resisidence that is fully detached, maybe fire separation is a non-issue.
The other part of my question was whether 4 x 1" dia conduit was enough for a 230 FT2 greenhouse, for lighting fans and controls. The floor is heated with hydronics so electric heat will not be used.
Any recommendations will be appreciated.
Thank-you,
Ted.
09/21/2009 10:07 PM
How big is the area?
Length width height
What equipment are you putting in there?
How do you have a civil engineer design the floor?
If you do not have the weight of equipment
If you know the weight?
You know the load requirements?
You have the electrical load
Your next step is to calculate
Circuits, voltage, amp
Wire size
Distance of your from distribution
To point of use (location of equipment)
Adjust wire size for voltage drop for distance
And now you have what you will use
Keep in mind
Not have more than 3 circuits in
1 electrical raceway run max (tube thru floor)
Adjust your tubing for wire size
And leave a 24 in open for all the rest (Joke)
Match your design plan to local codes
Use a steel oversize pipe thru floor
Project 1 inch above concrete floor
And 1 inch below concrete floor (ceiling)
Stuff inside with Styrofoam , toilet paper, penthouse
Pour concrete, remove foam, or pics
Run your electrical pipes PVC / EMT?
Thru sleeve
Then use fire retardant foam filler between sleeve and PVC / EMT
fillers are rated for fire per hr per deg
And note I could be wrong
oh why is there double space when I type
Complexity is only compounded simplicty :Johnny Flash 1960
09/22/2009 4:36 AM
Hi Ted,
It's been a number of years since I have had to deal with fire penetration issues for piping and conduits (in Vancouver) and I am not familiar with the Ontario Building Code, except that it is likely derived from the National Building Code.
Locally, for single family residences, fire codes do not require the same treatments as for commercial or multi-residential units. For detailing of firestopping and penetrations through various structures (wood and concrete) of various FRR I have used the details from Passive Fire Protection Partners (formerly Firestop Systems). You can likely find what you are looking for there in terms of detailing based on the construction. I would double check with the local code or code officials though just to be sure regarding any code issues and applicability. Although they may allow you to perform your own work, they will likely still require an inspection to ensure it is "kosher".
As for the other part of your question regarding capacity of what you propose, I cannot say as my background is in Mechanical engineering, not Electrical.
Here's the penetration detail link: http://www.firestop.com/listings/searchmain.asp
Cheers,
Duane Tilden, P.Eng
09/22/2009 4:13 AM
you can go ahead i have done it in several commercial projects including several Star hotels in India In fact you can create duct in the slab for electrical cables in consultation with your Civil/structural engineer, only precaution to taken is to insure your PVC conduit doesn't get chocked while pouring concrete.and insure that both ends of the concrete are plugged before you pore the concrete
crm
09/22/2009 4:16 AM
sorry for the error in my last sentence i meant both ends of conduit not concrete
crm
Good Answers: 18
09/22/2009 7:57 AM
Your fine, just be sure you fireseal any gaps once you run the conduit and circuits. UL/CSA rated PVC conduit meet all fire requirements of most countries.
09/22/2009 10:43 AM
Use a female adapter on the pvc pipe and screw on Rigid Steel Conduit 90 to stub-up through the concrete. (Factory steel 90's are readily available) Tape the steel from just above to just below where the surface of the concrete will be, because this is a very corrosive area. This will protect the conduit from rusting-out where it exits the concrete.
12/03/2009 6:58 PM
How many floors you have?
Where is the pipe running from and to?
The size of the pipe is more than enough for many wires! However; if you are planning on running more than 4 conductors other than the ground wire (green or bare) you need to consider the increase of the size of wires.
You can use table 310.15(B) (2) (a) NEC 2005.
Once you determine the factor, use table 310.16 NEC 2005 to choose the right size wire.
mike holt website has soom good tools tou can use.
MCS Electrical
www.mcselerctricalinc.com
MCS Electrical & Handyman
Register to Reply 10 comments
Anonymous Poster (1); Duane Tilden (1); GRAY HAIRED OLD GOAT (1); Johnny Flash (1); lyn (1); mcsinco (1); murali (2); passingtongreen (1); TedT (1)
