Previous in Forum: Pipeline Accessories   Next in Forum: Gas Engine Ventilation Calculation
New Zealand - Member - Member Papua New Guinea - Member - Lapun
Steam Turbine - Steam Rate
09/22/2009 1:40 AM
I am just looking for a quick idea of an approx steam flow rate that I could expect from a steam turbine driven air compressor.
Assume -
  1. present installed drive is 750kWe
  2. steam inlet P1 = 150psi, with some superheat
  3. steam outlet P2 = 30 psi
I know this is a bit vague, but I am just trying to get a better handle on what the steam flow rate may be. I have 30 tonnes per hour available at 150 psi, being the incremental flow available from the 1st stage of one of our turbo alternators.
from the beautiful central North Island of New Zealand.
Good Answers: 58
Re: Steam Turbine - Steam Rate
09/22/2009 5:28 AM
Try this calculator . If it does not give you what you want let us know.
09/22/2009 11:03 PM
Prof - many thanks for that - just what I need. I will run several calcs on different parameters so I can plot steam flow rate against various power and exhaust pressure scenarios.
I take it you are a sugar industry engineer?
regards from New Zealand.
Good Answers: 58
09/22/2009 11:46 PM
Pleasure. No, not the Sugar Industry, though my home in South Africa is in Durban which is in the cane growing area, and I have done a bit of consulting to the industry. Just get to play with lots of steam turbines etc all over the place.
Visited NZ early this year, what a beautiful country you live in. Could retire there if they would have me.
09/27/2009 2:53 AM
You have to find the Enthaly diference between enthalpy at p1 & enthalpy at p2.
This will be in kJ/kg. Them divide the drive power by this enthalpy difference which will give you the steam flow rate in kg/sec.
Regards.
Anant.
09/27/2009 1:35 PM
Thank you - much appreciated.
Anonymous Poster (1); Coinneach (2); The Prof (2)
