Previous in Forum: Understanding Greenhouse Gas Inventory (UNFCCC)   Next in Forum: Nobody invited the Red Wings to G20
Will a Larger Pipe Make Our Sprinkler Work?
09/24/2009 2:26 PM
This year the sprinkler on our cricket field fails to operate but there is no alterations to supply or pipework and the water company says that the pressure meets their criteria (one bar at source).
I think that the pressure has been reduced but cannot prove this, if we increase the diameter of the supply pipe to our tap from 3/4 inch to 1 inch thus creating more volume would this cure our problem.
Regards
Jim
Good Answers: 97
Re: Will larger pipe make our sprinkler work.
09/24/2009 2:38 PM
It may improve it but not solve the problem.
You should find the problem. Was there new development above or below you?
The municipal mains are usually ring mains (that is the water may reach you from more than one direction). if some of the isolating valves are closed the water may have to take a longer route to reach you and lose pressure.
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
Re: Will a Larger Pipe Make Our Sprinkler Work?
09/24/2009 9:09 PM
"One bar at source" (15psi) sounds horribly low for a water supply pressure. You could normally expect around 60-100psi as a supply pressure and if this is the pressure at the supply point but the sprinkler is not "sprinkling" one possibility is a build-up of debris (rusting pipe matter, dissolved soil from repair exercises) clogging up the sprinkler holes.
09/24/2009 9:45 PM
Bigger pipes won't help. You need more pressure. Or you have a restriction. If 3/4 worked before.........................................
Good Answers: 101
09/24/2009 11:27 PM
One bar at source is very low. I suggest you check to see if your pipe is leaking or clogged first. A leaking pipe should be easy to locate: look for spots where the grass is greener and growing more lushly than others, or where the ground is inexplicably soggy.
Hobbies - Musician - Tube Amps Only Please!
11/06/2009 8:50 PM
Get a big water pump.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
AussieBob (1); DVader1000 (1); Hendrik (1); lyn (1); maveric_manic (1)
