Previous in Forum: x'mer   Next in Forum: ELCB RATING
Serial Inputs and Outputs
09/28/2009 2:58 PM
I have two ARM processors and the TXD and RXD serial input/outputs are said to be an rs-232 connection or w/e it is required to transmit.
I just do not see the point of using an rs-232 DB9 connector to even transmit the information. here's the question, should I be able to just connect my Transmit out PIN from one ARM Processor to the Read in PIN of the second ARM processor?
The way it will be set up is a one sided input and output
[ARM1] ---> (TXD serial out) to (RXD serial in) ---> [ARM2]
please explain why or why not it would work.
thanks
Good Answers: 97
Re: Serial Inputs and Outputs
09/29/2009 6:08 AM
You also have to connect the common / signal ground.
And what about your hand shaking lines.
Reply to Forum Thread
