Previous in Forum: Connect NAMUR sensor with Data acquisition card   Next in Forum: Space heater rated voltage
9 comments
Proper Way to Install a AC250V/DC28V 8 Pin Relay
10/01/2009 9:40 AM
Need to know how to connect my AC250V/DC28V 8 pin cubic Relay to my DOL Starter ???
Re: Proper Way to Install a AC250V/DC28V 8 Pin Relay
10/01/2009 10:39 AM
What are the markings on the relay (manufacturer, part number etc)?
10/01/2009 11:16 AM
ITS a DTN TYPE TLY2, its 10A AC250V/DV28V other makring are TLY2 24LT AC24V its 8 PIN and it a Normally open Circuit Relay.
10/01/2009 11:43 AM
i want to use it as a Pump Start relay connected to my DOL starter. A electronic timer will start it on the other end of the relay.
10/01/2009 3:05 PM
Does it look like this:
... with a relay base like this ...
10/01/2009 11:03 PM
yeah looks like that
10/01/2009 8:23 PM
Boy. you sure doesn't know how to read the relay specification.
"DTN TYPE TLY2, its 10A AC250V/DC28V other marking are TLY2 24LT AC24V"
Your relay is 8 pin relay and the relay coil is rated at 24Vac. The capacity of the relay contact can handle maximum 10 ampere at 250Vac load or at 10 DC ampere at 28Vdc load.
Correct me if I am wrong.
10/01/2009 11:02 PM
um.... i do know how to read it. and i could have told you all of that. yes it looks like that pic. I didnt get any diagram or specification on how to wire it to my DOL thats the problem i got!!!!
10/02/2009 12:05 AM
How do you want this relay connected to your DOL Starter?. And what do you want this relay to do for you?.
This relay is for control and other small signal to used. It cannot drive a motor with high current. Maybe if you can tell us more about your problem, perhaps we can assist you on your problem.
10/02/2009 1:46 AM
thanks all, figured it out :P cant belive how simple it was :( cheeeer again
Anonymous Poster (5); JohnDG (2); Simon Wan (2)
