Did you know that Vacuum tubes say in a Guitar/Bass Amp can have severe shortened life span? One reason is playing at near full volume. The Phase Inverter and Power tubes are stressed at full power compared to low volume so I do not buy expensive Mullard NOS Power tubes which can run hundreds of bucks. The preamp tubes can last a long time especially Telefunken.
Also the vintage amps everybody craves are a engineering nightmare they were not completely designed right in fact some of the designs came from the RCA Tube books with example at the back of the book. Examples: 2 prong plugs with pseudo earth ground, no standby switch, poor HV filtering, no screen grid resistors, early distortion breakup etc. The moral of the story is to improve the vintage design with Bouquet Amp design which over kills the vintage design with improved tube design tricks. Not using a Standby switch will eventually destroy the cathode coating. You must warm up the tubes and stabilize the HV tube BEFORE applying HV to the Plates of all tubes.This is done manually with a switch after 30 seconds minimum of warm up time. I have a circuit that does this with only the power switch and a red/green LED that tells me when HV has been applied. Otherwise you can kiss those expensive tubes good by after a while by applying HV with no warm up time the cathodes do not like this.
Vacuum tube design is a lot of fun and if you are a musician you know how expensive they are so I built my own Boutique style. You could not pay me to play on a transistor amp totally dry no comparison to a tube amp with good components and tubes.
