Previous in Forum: Welding Rod for Ni20Cr2 Casting   Next in Forum: Random Vibration - Designing an Electrodynamic Shaker
Anti-Cavitation Valves
10/06/2009 5:44 PM
Hi,
When do we use an anti-cavitation check valves?
Good Answers: 101
Re: anti-cavitation valves
10/06/2009 8:07 PM
Please be more specific, or you might just get an answer like this one:
Whenever they are needed to prevent cavitation.
Or you can check here, and get back to us.
10/06/2009 10:18 PM
Re: Anti-Cavitation Valves
10/08/2009 3:03 AM
Whenever the pressure downstream of the valve falls below the vapour pressure of the liquid being controlled at the conditions of flow and temperature at the worst conditions.
bioramani
10/08/2009 8:16 AM
If the presure downstream is lower than the vapor pressure then FLASING occurs,that is part of the liquid vaporizes.
For cavitation to occur liquid must go below the vapor pressure and then recover to a pressure higher than the vapor pressure.
There are many number of excellent write up on these on the internet.
Visit the web site of Fisher,Masneilan,Flowserve ,Samson etc.
If you don't know where you are going,you are bound to get there
10/09/2009 2:12 AM
Agree. Usually vortices lead to such excursions of pressure and cavitation. I was referring to an unsteady state situation. Flash vapourization does result if there is a continuous low pressure condition.
We have seen cavitation damage even at the edge of rigid discs of mechanical heart valves.
bioramani
bioramani (2); Mikerho (1); RVZ717 (1); srini (1)
You might be interested in: Check Valves, Gas Valves, Hydraulic Valves
