Previous in Forum: Paint Can Rotation System   Next in Forum: Calculation of Tonnage
Pulley Specs
12/29/2006 11:59 AM
I urgently need to know a pulley material equivalent to BSS 1456A in either ASTM or AISI. The application is crane pulleys. Hope you all had a Happy Christmas (if relevant) and Best Wishes for the New Year.
Good Answers: 19
Re: Pulley Specs
01/06/2007 8:59 PM
Ask the pulley manufacturers
Re: Pulley Specs
01/06/2007 11:01 PM
Thanks. But that is precisely what the crane operator wants to avoid, so he can develop a spec from this side of the Atlantic.
Re: Pulley Specs
02/05/2007 8:30 AM
I have found some mentions to BSS 1456A as a cast (grey) steel.
As you are in a hurry and your application is not so precise, what about using laminated steel to build them?
Humm... suspicious you are...
Re: Pulley Specs
02/05/2007 9:15 AM
The alternative here in Mexico seems to be a low alloy hot rolled hollow bar product. (Heavy wall mechanical tube). But I do not think that a laminated product like this, and as you suggest, is the answer. Roger
Re: Pulley Specs
02/05/2007 10:27 AM
I see. I was thinking about a thick plate, but...
Ordiary grey steel would fit. Check against some typical load values, this kind of things usually are not so heavily-stressed materials.
Anonymous Poster (1); bhrescobar (2); ducon (1); Raknruin (1)
You might be interested in: Idler Pulleys, Round Belt Pulleys, Drum Pulleys
