Previous in Forum: What's the "B" in a 7302BDF Bearing?   Next in Forum: Surface Finish of a Shaft Journal
Radiographic Test Standard
10/13/2009 7:13 AM
dear every one,
can you please answer me about this case:
i have 1G joint base meatal 12 mm thickness ( steel structure(I) beam welding)
is the acceptance standard for the (x-ray test ) is asme secVIII...
i take x-ray for the joint i find that porosity 3mm separated at 5mm is it acceptable or not???
regards
Re: radio grphic test standard
10/13/2009 8:38 AM
This is an exact copy of:
ACCEPANCE ARITERIA, to which no one responded. There must be something strange here.
Re: Radiographic Test Standard
10/13/2009 11:34 PM
What is your Code of condtruction, Sarmad? Sec VIII is for pressure vessels. I am sure you know it. If what you have welded is per that then look up for your X-Ray results under UW 51. Or else, you have to follow the applicable Code criteria.
Register to Reply 2 comments
