Previous in Forum: Squirrel Cage Electric Motor   Next in Forum: Wanted: EMI Testing Service
Battery Charging
10/13/2009 8:53 AM
i have 6 volt battey in emergency light but i would like to know i much maximum DC voltage is reguired for a chaging of 6 volt battery (6 volt, 4.5 Ah)
Re: battery charging
10/13/2009 9:25 AM
It would help if we knew what type of battery it is....
But besides that the first place to look is on the manufacturer's web site, or give them a call, they will know what you need to charge the battery.
10/13/2009 9:51 AM
The emergency lights I have seen are under a constant charge state (standby), until domestic power drops out; when power outage, the emergency light draws stored energy from battery, and provides illumination. This charging is thru transformer from domestic power, 120VAC... (sometimes 277VAC?). Are you not using the standby battery and emergency light in this fashion?
Good Answers: 32
Re: Battery Charging
10/13/2009 11:21 PM
To keep a 4.5Ah lead acid battery on standby you would need 6.8 Volts REGULATED with up to 500mA current capability. Don't use a non-regulated charger/supply or the battery will over charge and dry out when it vents. Also take care as some regulated power supplies/plug packs don't like being fed voltage if they are turned off(no AC power to them).
johny451
Register to Reply 3 comments
Doorman (1); Electroman (1); Johny451 (1)
You might be interested in: Emergency Call Systems, Battery Holders
