Previous in Forum: Battery Charging   Next in Forum: Undervoltage Relays
Wanted: EMI Testing Service
10/13/2009 9:29 AM
Any idea about ELECTROMAGNETIC INTERFERENCE (EMI ) DIAGOSTICS TEST On GENERATOR , TRANSFORMER AND MOTOR ? i am looking for any company in uk who can do the test?
Hobbies - Musician - Tube Amps Only Please!
Re: Wanted: EMI Testing Service
10/13/2009 9:09 PM
I have use this type of service in the USA but you need to Google and search the web. This kind of question simply requires searching the net. You will be amazed what you can find.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
10/14/2009 3:27 AM
cant find it!!!!
United Kingdom - Member - Hobbies - HAM Radio - G7TSP Engineering Fields - Electrical Engineering -
10/14/2009 3:48 AM
Mead Testing Ltd
Unit 25 Mead Industrial Park
Riverway
Harlow
CM20 2SE
Essex
Tel: 01279 635865
Fax: 01279 635874
www.meadtest.com
I've used these guys on several occasions for EMC testing of our designs.
10/14/2009 4:31 AM
10/14/2009 5:01 AM
Thank you ..but it is EMI test..
10/14/2009 5:14 AM
Electromagnetic interference (EMI) is said to exist when unwanted voltages or currents are present so that they adversely affect the performance of a device or system. Such voltages or currents may reach the victim circuit or device by conduction or by nonionizing radiation. In all cases, electromagnetic interference arises because of a combination of three factors: a source, a transmission path, and a response, at least one of which is unplanned. Electromagnetic interference control refers to the process of making design changes or adjustments of signal or noise levels in order to achieve electromagnetic compatibility (EMC).
10/29/2009 1:20 AM
Which country you are in?
There are hundreds of testing service providers.
I can give you addresses once I know your location.
Register to Reply 7 comments
gsuhas (1); Lemmy70 (2); maveric_manic (1); Randall (1); saidussadat (2)
