Previous in Forum: Wanted: EMI Testing Service   Next in Forum: MOT Spot Welder
8 comments
Undervoltage Relays
10/13/2009 12:47 PM
Why there is only one undervoltage relay sometimes in PCC(power control centre),415V level instead of two undervoltage relay coils across any of two voltage lines. ???Pls give some idea.
"Know something about everything and everything about something"
Good Answers: 73
Re: Under voltage relay....
10/13/2009 1:13 PM
Perhaps the application to which you refer is simply a single phase circuit. There are also three phase voltage monitors. You can buy as many features as you desire for those devices. That includes under voltage, over voltage, phase loss or imbalance, phase reversal, over frequency, under frequency, and ground fault. I hope that gives you enough ideas.
Good Answers: 804
10/13/2009 1:33 PM
And sometimes people use a type of relay that monitors only one phase, but is set up so that an imbalance caused by a loss of either of the other two will be something the relay will detect and trip on. It works, but the relay has to be very sensitive and thus prone to nuisance tripping from disturbances caused by normal operations. I prefer to monitor all 3 phases for both voltage and current.
10/18/2009 2:47 AM
Pls anybody can provide more insight into this?
10/21/2009 4:06 AM
The most obvious reason I can think of is cost savings. Nothing else. It would be more prudent to use at least two undervoltage relays - one connected across 'R' & 'Y' and the other connected across 'Y' & 'B'. Still better would be to connect three relays rated at 240 V, connected between each phase & neutral - provided your network source is star connected.
Good Answers: 73
10/22/2009 1:04 PM
Check out this link.
10/29/2009 1:22 PM
Anybody pls...........those relays were of english electric make VAGM.....
Good Answers: 804
10/29/2009 9:13 PM
Jeez... quit begging.
10/30/2009 10:50 AM
***** you....You forced me to tell this
Register to Reply 8 comments
Anonymous Poster (1); giri (3); JRaef (2); NotUrOrdinaryJoe (2)
