Previous in Forum: Hysteresis Loss in Core   Next in Forum: motor
Turkey - Member - New Member
Circuit Breaker Performance
10/14/2009 3:48 AM
high voltage circuit breaker performance is affected by atmoshperic conditions such as atmoshpere heat etc...especially with altitude the ratings change or not?
jinxnao
Re: circuit breaker performance
10/14/2009 4:56 AM
IT MUST BE COMPLY WITH UR DATA SHEET......GO THROUGH AMBIENT RANGE AND THAT RANGE MUST BE COMPLY WITH BREAKER. IF BREAKER COMES WITH ENCLOUSER THEN GO THROUGH ATEX CERTIFICATION WHERE IT MUST MENTION THE AMBIENT TANGE.
U R RIGHT ATMOSPHERE INFLUENCES BREAKER PERFORMENCE.
REGARDS
DAVID
10/14/2009 4:58 AM
REGARDS
DAVID
10/14/2009 5:21 AM
Re: Circuit Breaker Performance
10/15/2009 4:13 PM
Definelty the rating of the any High / medium voltage switchgear and circuit breakers will come down due to increase in altitude. Every switchgear manufacturer will give this data. For example a siemens switchgear which is rated for 15KV at normal conditions (normal alititude is 1000 m) if elevated to 2000m its capacity decreases to 13.5 KV approx. This correcton factor is as per ANSI and IEEE. But there is a continous review happening with in IEEE about the correction factors.
You may refer to the standard for exact correction factors ANSI/IEEE C37.20.2
Mind is like a parachute, no use if you do not open it
Register to Reply 4 comments
Anonymous Poster (2); imandi007 (1); JohnDG (1)
