Previous in Forum: 6VDC Biometric Sensor   Next in Forum: Having problem with 2-way radio
Two-Pole Connection
10/16/2009 10:55 AM
Hello!
I have circuit connect on 2 pole breakder in 120/208v panel connect phase-phase. For power calculation do I use:
P=208*I*PF
If not what do I use please? What do we call this, 2-phase? 1-phase?
Thankyou!
Re: 2 pole connection
10/16/2009 11:16 AM
Correct if you know the values of V, I , and PF.
For me phase-neutral voltage is "phase voltage",
phase-phase voltage is "line voltage",
so there is no "phase voltage" in the supply whose transformer is delta connected,
Good Answers: 244
10/16/2009 11:16 PM
The power formula is correct.
It is still 1 phase (line to line or 2 hot wire) supply. Unlike phase to neutral supply, you have to use protection in both lines (either by 2 pole breaker or fuses in both lines).
The idea of 2 phase supply (4 wire system) is completely different and it is an old system, not used now a day (http://en.wikipedia.org/wiki/Two-phase_electric_power).
- MS
Re: Two-Pole Connection
10/17/2009 12:40 AM
Hi,
What is connected to this supply- load?
Formular is correct
P=V*I*PF
Thanks,
Joseph
10/21/2009 5:09 AM
it is the voltage line to line 208 -----if it is 120 then it is line to phase
Correct me if i am wrong i am learner
ikhanuk (1); joseph sithole (1); msamad (1); Yuri B. (1)
