Previous in Forum: Schedule Numbers and Pipes   Next in Forum: Induction Motors and End Rings
Shafts and Assembly Bullets
10/21/2009 10:27 PM
assembly bullet
sort of some device attached at the end of the shaft
anyone here knows what exactly is this thing?
I am not a home work cheater. I am a translator seeking professional help
Pathfinder Tags: assembly bullet
Re: “assembly bullet ”meaning
10/21/2009 11:40 PM
If you are trying to assemble a rod, tube, or pipe into a place where it must pass through a hole, the piece you are inserting may sag and encounter metal instead of the hole. An "assembly bullet" is a pointed tip (bullet-shaped, hence the name) that guides the inserted piece into and through one or more holes, such as in perforated plates or baffles. This is common in shell-and-tube heat exchangers, for instance.
10/22/2009 2:05 AM
thanks for the assist
Register to Reply 2 comments
You might be interested in: Core Shafts and Mandrels, Rotary Shafts, Linear Shafts
