A plant I work at utilizes this grounding system for 2400-480VAC Delta-Delta Substation transformers. As I understand it was incorporated to help maximize control of severe transitory overvoltages and a return path for ground faults currents, with minimum component and installation expense. Going with this, fusing is not required or permitted in the grounded phase (NFPA-70, 240-22), throughout the downstream distribution, as it could disrupt fault current path to ground, restricting operation of upstream overcurrent devices.
Does anybody know where I can more info about this kind of grounding system? If possible, perhaps in simple explanations?
Also, if anyone can share their experiences about this system, it would be great.
