Hello Everybody,
Our refinery has motors of various sizes and some of them have VSD installed. I have found out an issue, whereby the thermistor of a motor has the maximum resistance of 3K ohms. The thermistor relay on the VSD expects to see 4.7K ohms to trip the motor on thermistor. I understnad this a design issue. The VSD has a thermal model which will trip the motor if it gets overheated. The issue is the thermal model does this on the basis of the temperature of the motor and not particulalry on the thermistor. We had thermistor trips in the past although the relay wont trip under 4.7k ohms. How is this possible? Is there a danger where by the motor windings burn out before it trips. There is suggestion to have resistances in series with the thermistor to brig up the resistance to 4.7k Ohms. But will this work. theoritically it will, but how about the practical aspects. I dont want to stick resistances on the thermistor and trip the motor every now and then. Has any one come across such an issue? Inputs will be appreciated.
