Previous in Forum: Pneumatic Test with U-Tube Vertical Manometer   Next in Forum: Heat Input
SAW Wires and Fluxes
10/22/2009 8:42 PM
Please advise SAW Wires & Fluxes Brand/Type normally used in fabrication of pressure vessels.
Also advise on Flux Core wire used if Co2 as the shielding gas!
Thanks and Regards.
=D
Re: SAW Wires and Fluxes
10/24/2009 3:20 AM
• The following table includes a variety of fluxes and wires used in SAW:
• The following link is for WPS's & PQR's used in a job for fabrication of pressure vessel fabricated from carbon steel, and both processes SMAW and SAW: WPS's & PQR's
• The following links are very interesting for filler metals: ESAB_Basic_Welding_Filler_Metal_Technology & ESAB Filler_Metals_Handbook
• There are a lot of international welding companies producing the wires and fluxes used in SAW such as: ESAB, Lincoln, Hobart, ... etc.
Good Answers: 18
10/24/2009 1:43 PM
There are lots of brands available in different countries for SAW, FCAW, GMAW, SMAW and other processes also. It is up to us to select a particular type which again depends up on your experience with brands, its popularity among the user circles, approvals by third party Inspectors/ surveyors, availability of particular combination matching your base metal and not but least its Quality, Consistency, and prices .
The choice is yours. Even if locals ones are available you can conduct tests, make a WPS and PQR , qualify them. There is no hard and fast rule saying that you have to go for a particular brand.
Generally we choose min. 2 brands depending upon its availability and quantity requirements.
Some of the renewed brands are Esab, Oerlikon, Lincoln, Hobart, Sudometal, Alloy rods etc. They all work with agglomerated flux and you can get these and many more in Singapore and Malaysia.
For carbon steel materials you follow, ASME Sec. II part C. SFA 5.17 and for Alloy steel - SFA 5.23 codes. Depending upon your base metal chemistry, strength, PWHT, choose your requirement from EL8 , EM12K, EH14 etc.
Similarly, Lots of Flux cored wires are available for welding Carbon steels (AWS SFA 5.20), Alloy Steel (AWS SFA 5.29), SS 308L, 316L, 309L 410, 430 etc., (AWS SFA 5.22), hard facing & surfacing applications and for use with CO2 gas..
Trust above details will help you in choosing your right requirement.
Sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
10/28/2009 10:57 PM
Thanks.It helps me so much!!!
=D
Register to Reply 3 comments
Abdel Halim Galala (1); hafizan (1); SRIDHAR (1)
You might be interested in: Fluxes, Saw Blades, SAW Filters
