I have this plan to eventually make my computer refrigerated. One of my friends made his computer water cooled, but I wanted to out dork him with some REAL engineering, instead of buying pre-made stuff. I actually tried peltiers, one was 84 watts, and the other was 50 watts. From the beginning I knew it wouldn't work, but both had incredible heatsinks on both sides, so the hot sides would actually be only slightly warmer than room temp. Without fans on the cold sides, both would develop frost at the very center. Unfortunately, the computer generates an easy 300 watts of heat (in serious processing or gaming), and just because peltiers are so inefficient, the computers parts were actually much hotter "cooled" with the pelts, than without. And duh, the hot side was on the outside, and the case was sealed off with the pelts installed, and all the parts inside have good heatsinks. I think that I would need at least a 400 watt peltier to dissipate 300 watts of heat, and still have some leeway. But the problem is, with those stupid pelts using 134 watts of energy, and the computer using 300 watts or more, the room starts to get very very warm. Plus, I felt bad about so unnecessarily using so much energy.
So my question is, what would be a good way, of actively cooling something that generates 300 watts or more heat? I want to be able to control the temperature to below ambient. The power supply powering my computer (actually not in my computer but next to my computer) is from an IBM server tower. It has two 560 watt supplies, each rated for 30 amps at 12v, so that leaves lots of opportunities for peltier coolers. I was thinking that a compressor type refrigeration unit from a mini-fridge would be perfect, but it there would be the resulting noise, which would make it undesirable. My dad works for an energy management company, and has experience with refrigeration, so taking apart a unit like that, re-piping it etc wouldn't be too far fetched, but would be a little beyond this project I think.
Another idea is to have a huge peltier, and have some kind of thermostat circuit. Use a solid state relay, for quietness. Having a thermostat would make it a little more efficient too, only being on when needed. I figure that cooling all of the air inside will make it easier to cool everything, including the hard drives. The life of a hard drive increases dramatically, when cooled below 100 degrees F.
But the problem still remains, that it is using a tremendous amount of power, and heating up the room. Any ideas on a practical cooling method? I figure in the engineering world, there has to be something that is better than what know about.
Also, any one who knows of a good supplier of pelts, heatsinks, temp controls that are good about selling samples in small numbers. It's one thing to google those things, but to find a company that's willing to sell just one unit is another. (so don't yell at me for asking where to find that stuff!)
Thanks,
-Nick
