Previous in Forum: Active PC cooling   Next in Forum: Rewinding AC Generator Alternators
Humidity Sensor for an Incubator
01/07/2007 5:25 PM
I am working on an incubator [tunnel type]. The humidity sensor is bad. I replaced with new but one all the reading i got is 01. All parameters to the input of the sensor are correct. What could be the cause as a humidity sensor from another machine worked with the machine but all the new ones refuse to work?
Re: Humidity Sensor for an Incubator
01/08/2007 7:06 AM
Well, I would check that the new ones are the correct type and haven't had a design change that might make them refuse to work with your system...
If a sensor from another unit works sounds like the new sensors are possibly faulty?
John.
01/09/2007 4:04 AM
Vaisala is a recommended cost effective source for humidity, dew point, wet and dry bulb temperature instrumentation.
01/09/2007 7:26 AM
What's that got to do with Johnny's problem??
John.
01/09/2007 8:46 AM
Learn to read Psychrometry Charts to read off humidity%.
Use a Dry bulb and a Wet Bulb Thermometer--and interprete!
Thermometers always work.
01/09/2007 9:45 AM
Again, as Electroman said: "What's that got to do with Johnny's problem??"
Sorry Electro, I couldn't resist.
Johnny, I assume you are not trying to design a new incubator, and the one you have is automated so swinging two thermometers around probably won't interface well with the control system. I think you might get more help if you explain the make and model of the unit you are working with; another assumption that it is not a one-off device. If you post the manufacturer and model of the machine you might get someone that's worked on them before to help you. I am sorry I don't have any more useful suggestions, but I cannot even go lookup info for the machine you are using; which I might have done just out of curiosity.
01/09/2007 10:29 PM
Corn Stoves
Register to Reply 6 comments
Anonymous Poster (1); Cornstoves (1); Electroman (2); juba-jabba (1); MUKULMAHANT (1)
