Previous in Forum: Regenerative Braking   Next in Forum: Temperature Data - Locomotive Type Boiler
Heat Transfer in a Locomotive Type Boiler
11/09/2009 6:33 AM
Taking the case of a conventional locomotive type boiler, I am seeking information on the mechanism of heat transfer from the furnace side of the boiler's firebox wall through to the water side of the wall. In particular, I wish to arrive at an understanding that will permit me to estimate the probable temperature gradient across the thickness of the metal wall of the boiler's firebox, given varying assumed deposits on either side of the wall.
Has any person been able to gather actual temperature readings from either side of the firebox wall of an working locomotive boiler, by, say, the deployment of suitable thermocouples?
I have searched through related available text books for detailed information, to no avail at this juncture. A copy of the required text or direction to an appropriate information source will be most welcome.
Re: Heat Transfer in a Locomotive Type Boiler
11/09/2009 7:18 AM
<...available text books for detailed information...>
→ "Fundamentals of Heat, Mass and Momentum Transfer", by Welty, Wicks & Wilson.
Good Answers: 15
11/10/2009 12:20 AM
You do realise that the firebox extends from the front of the cab to the front of the engine?
in between the actual firebox and the smoke stack at the front, you have heat runner tubes of varying sizes distributed through the liquid to be heated, running axially to the boiler, this improves the heat transfer from the "fire" to the water inside the pressure vessel.
The steam from the pistons is taken by pipes to a position under the smoke stack, and the escaping steam blows up and out the stack acting as a venturi to assist in sucking the heat through the heater tubes.
So, in essence, the firebox wall isn't just a box at 1 end of the boiler, it is incorporated in the tubes.
In some cases, the steam take off on the top of the boiler is also taken through the firebox "hot" area to increase the heat (energy) that the steam is carrying.
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
11/11/2009 3:35 AM
http://www.nrel.gov/docs/fy06osti/39309.pdf
http://crtd.asme.org/eew/boilertube.pdf
http://www.toodoc.com/prevention-of-boiler-tube-failure-pdf.html
http://www.gewater.com/handbook/boiler_water_systems/fig12-2.jsp
bioramani
Register to Reply 3 comments
bioramani (1); PWSlack (1); Snaketails (1)
