Previous in Forum: Plumbness Test for Storage Tanks Shell   Next in Forum: Ultrasonic Testing of Pipe Weld Joints
9 comments
Hydrotest pressure hloding time
11/09/2009 10:00 AM
ASME Sec VIII Div 1 does not specify the duration for which the test pressure is to be held. So a few question arises:
1. Is there a thumb rule for this time?
2. If the pressure is held momentarily and brought down to design pressure, will it serve the purpose of the test?
3. Sec VIII Div 3 specifies a time for holding the test pressure. What is the philosophy behind not specifying it for Div 1 & Div 2?
4. What do other international codes say?
Re: Hydrotest pressure holding time
11/09/2009 10:47 AM
VIII. Pressure Vessels - Division 1
Basic Coverage
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig.
Such pressure vessels may be fired or unfired. Specific requirements apply to several classes of material used in pressure vessel construction, and also to fabrication methods such as welding, forging and brazing.
It contains mandatory and non mandatory appendices detailing supplementary design criteria, nondestructive examination and inspection acceptance standards. Rules pertaining to the use of the U, UM and UV Code symbol stamps are also included.
Contents
Scope & Service Restrictions; General Requirements; Requirements for Fabrication by Welding, Forging, or Brazing; Requirements Pertaining to Classes of Materials for Carbon & Low Alloy Steel;Nonferrous Materials; High Alloy Steel; Cast Iron; Clad & Lined Vessels; Cast Ductile Iron Vessels; Ferritic Steels with Tensile Properties Enhanced by Heat Treatment; Layered Construction; High Stresses at Low Temperatures.
if this is what you are referring to
install a pressure gauge into system if there is none
pressure the system at the design pressure
the design pressure if done right should have safety margin
I would not go over that PSI with out special precautions
check the reading if it drops after 24hrs
you have a leak in the system
Complexity is only compounded simplicty :Johnny Flash 1960
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
Re: Hydrotest pressure hloding time
11/09/2009 11:24 AM
Basically, from my experience and understanding, the ASME considers two types of hydro static tests:
Strength and Tightness;
Strength test is a 150% of design pressure test which is conducted once in a lifetime.
Thus
Every test after the once in a lifetime is a Tightness test of 110% of design.
Duration of testing: Suffient to verify the objective of the test.
Thus, if you are doing a strength or tightness test the time required for satisfactory results is the time required to do an adequate inspection to certify that the testing. Therefore, the criteria for a vessel is the time required to do the inspection. Vessel pressure must be held test pressure sufficiently long for the inspector to inspect the vessel. Same for a tightness test . . . how long it takes to inspect for leaks.
Note: A written test procedure should define the inspection requirements and may define a hold time.
A government big enough to give you everything you want, is strong enough to take everything you have.
11/10/2009 10:02 AM
It is my understanding that the test pressure in the current ASME code is 130% of the vessel design pressure (ASME Section VIII, Design of Unfired Pressure Vessels), having been changed in one of the more recent editions.
This is "off subject," however.
Good Answers: 11
11/09/2009 10:59 PM
Re 4. What do other international codes say?
Australian Standard AS 4037-1999 says:
AS 4037—1999
17.3.2 Application of test
The test pressure shall not be applied until the fabrication
and its test fluid are at about the same temperature.
The full test pressure shall be maintained for 30 minutes minimum unless otherwise
specified in the application Standard and preferably for one minute per millimetre of
thickness.
Prior to close examination of the vessel or component, the test pressure shall be reduced
to 85–95% of the test pressure and held for sufficient time to perform the examination.
11/10/2009 3:05 AM
hello,
As per ASME 31.1
For NBEP(Non Boiler External Piping) hydrostatic test pressure (gauge) at any point in the piping system shall not be less than 1.5 times Design Pressure(gauge),but shall not exceed mamximum allowable test pressure for any non-isolated compoent in the system such as valve etc.This should be maintain for minimum 10 minutes.Then reduce Test Pressure to Design Pressure and held it for examination of leakage in the system.
11/10/2009 9:47 AM
Thanks Malcom...that's a piece of useful information.
07/16/2010 3:26 AM
If ASME B31.3 is applied, what is the minimum holding time? And which pressure should be reduced to perform leak-test?
Engineering Fields - Piping Design Engineering - New Member
07/17/2010 5:41 AM
It's 10 minutes (minimum).
Go through this article. It may help you. http://www.thepetrostreet.com/article_0001.html
Regards,
Ashfaq
10/12/2023 9:54 AM
5. What does the Engineer/Surveyor for the company that is to supply burst/collapse indemnity insurance cover on this artefact have to say?
Register to Reply 9 comments
Anonymous Poster (1); ashfaqanwer (1); bm (1); flynnstar (1); Johnny Flash (1); Lahane82 (1); Malcolm Stephen (1); nukesub629 (1); PWSlack (1)
