Previous in Forum: Best Material for Septic Tanks   Next in Forum: Industrial Zippers
MASONARY MANHOLE CHECK
11/11/2009 4:24 AM
HOW TO CHECK THE BRICK MASONARY MANHOLE OF 230MM THICK,4' DEEP & 4' DIAMETER.
PLEASE SUGGEST ME THE PROCEDURE
Re: MASONARY MANHOLE CHECK
11/11/2009 5:11 AM
  1. Turn off Caps Lock.
  2. Get in the manhole and use Mk.1 eyeball?
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
11/11/2009 5:49 AM
Wha?
Oh, just get in it and have a look, Guv.
If you'd used Milton rings, you wouldn't have had to.
Can I get back to sleep now? <Splutter>
Essex jobs for Essex yobs! <Burp>.
11/11/2009 2:53 PM
I agree with PW & Stinky
A "first person" visual is your best bet
To Be Is To Do...Kant , To Do Is To Be... Sarte, Do Be Do Be Do... Sinatra
11/12/2009 12:12 PM
Good suggestions, but please attend a confined safety class before entering the manhole.
Follow the procedures learned to ensure that you make it out alive.
Good Answers: 179
11/13/2009 9:55 AM
Hello,
What's the reason you want to inspect this manhole for? Condition? Leakage?
Another question: Is this manhole on an active or dead sanitary sewer line?
WORD OF WARNING! Do not enter any manhole of below ground vault by yourself because of "CONFINED ENTRY" problems that can occur; you may run into accumulated gases or live high voltage electrical wiring while inside the manhole that'll probably kill you or anyone topside that tries to rescue you!
TAKE A CERTIFIED CONFINED ENTRY COURSE!!!!!!!!! It'll save your life!!!!!!!!! IF YOU PLAN ON ENTERING THE MANHOLE MAKE SURE YOU'RE WEARING A PROPER BREATHING APPURATUS, HAZMAT CLOTHING AND ARE HOOKED UP TO A SAFTEY LINE WHERE THEY CAN WENCH YOU UP AND OUT OF THE STRUCTURE!!!
Please, do play this manhole inspection dumb. And, don't be pressured by a Boss or Supervisor to do so either, as it's ultimately your safety and life at stake!!!!!! Good luck!
Have a great sunny day!
11/13/2009 10:23 AM
Hello Captain
Based on the dimensions given,bodily entry to make a preliminary assesment,hardly seems necessary!
I agree a co-worker should be present
I assumed it is a brick & mortar construction and an above ground visual inspection
seems like a logical place to start
Best Regards
Register to Reply 6 comments
Anonymous Poster (1); CaptMoosie (1); kay williams (2); PWSlack (1); Stinky Pete (1)
