Previous in Forum: Silicon Carbide Fiber Drawing Expert   Next in Forum: knowledge
14 comments
Stainless steel
11/12/2009 5:19 AM
What makes any stainless steel more shiney than other materials.?
Re: Stainless steel
11/12/2009 5:58 AM
The chromium within it?
Re: Stainless steel
11/12/2009 6:25 AM
It's a lot shinier than cork because cork has a rough surface at both micro and macroscopic levels.
Cat's eyes are very shiney especially at night as the light reflects back through the lens.
I expect you could make a stainless steel surface which wasn't shiney by sandblasting it.
Re: Stainless steel
11/12/2009 1:22 PM
Correct, we used to do this on stainless steel enclosures mounted on power poles on the side of the road to prevent passing motorists from being blinded by the reflected sunlight.
Re: Stainless steel
11/12/2009 8:13 AM
'All that glisters is not gold' - the original Shakespeare editions of The Merchant of Venice, 1596.
Re: Stainless steel
11/12/2009 10:52 PM
Well done. So tired of hearing "glitters"
Re: Stainless steel
11/12/2009 8:42 AM
Good Answers: 101
Re: Stainless steel
11/12/2009 8:48 AM
Chromium.
Good Answers: 19
Re: Stainless steel
11/12/2009 11:03 AM
the (fine oxide layer on) chromium prevents the steel from tarnishing, but it is possible to get a mirror finish on ordinary steel by polishing; unless protected it will then rust.
this was done to the rear mudguard of a chopper in build or bust; it was then laquered for protection
Re: Stainless steel
11/12/2009 11:10 PM
So, can I conclude that cromium plays major role in Stainless steel in case of its shine?
Re: Stainless steel
11/13/2009 12:46 AM
Surface finish gives it the shine - chrome helps to keep it there..............why do I do this to myself................
Re: Stainless steel
11/13/2009 2:25 AM
Maybe, but shine is ALL ABOUT SURFACE FINISH.
Re: Stainless steel
11/12/2009 11:12 PM
What makes us driven to answer even the most inane questions from the likes of you?
Good Answers: 93
Re: Stainless steel
11/15/2009 11:06 PM
Keeps us young for one thing.
I am Refreshed I tell you Refreshed!
For instance, I immediately thought, "If you don't like stainless steel, get some Monel."
Then I thought, well, stainless steel is probably cheaper.
Then I remembered how you have to put some rubber gasket there to prevent electric corrosion when using the Monel on the ships railings.
Then I forgot something, and considered how many places have Chromium, and why we really need it.
After that I began to think of superior ceramic and glass and waited for a call from Corning to give me head to make engines from sand and whatnot, instead of copper, nickel, iron and chromium.
Then I returned to some rumination on the carbon nanotubes needed for the Space Elevator on Mt. Kilamajaro. After that I compared the weather there to that in Ecuador out about 50miles into the sea and think finally that both locations are good.
You don't get wise because you got old, you get old because you were wise.
Re: Stainless steel
11/16/2009 4:52 AM
I thank you all, for your suggestions....!!
Anonymous Poster (3); Calnet42 (1); DVader1000 (1); HUX (1); jack of all trades (1); lyn (1); nahush (2); PWSlack (1); Transcendian (1); user-deleted-1105 (2)
