Previous in Forum: Requirement of Grounding of Cable Glands within SS JB using a wire   Next in Forum: Using Pressure Gauges on Oxygen Service?
8 comments
orifice plate..help me
11/14/2009 2:46 AM
I have received a Restriction orifice plate from vendor for NGL fluid
pipe is 8" in upstream and downstream.
flange size 8"/150lb/RF, but received plate is not RF.its a flate plate.
recived Outer diameter is 280mm , how to find wheather this diameter is ok or not.
Bore diameter=40.63mm ( matches with our specification)
plate thickness=9.63mm (matches with specification)
differential pressure drop is 145 psi
normal pressure is - 151.5psi
temp-120degF
Base pressure - 14.7psia basetemp-60degf
Cp/Cv=1.764
beta ratio= 0.2 ( matches with our specification)
specific gravity - 0.6471, Mol weight -93.62
My question is how to findout whether the outer diameter is ok or not
RF is required or not in the plate
inlet bore is not tappered its circular , wheather tappered hole is required or not
pls reply, help
Re: orifice plate..help me
11/14/2009 5:14 PM
If the flanges between which this orifice plate is to be installed are RF, the flat orifice plate is fine. You can check the bolt circle and bolt diameter dimensions to make sure the 8.60 o.d. plate fits within the bolts (I'm pretty sure it will). If there is lots of clearance, measure the plate when you install it so that it is centered within the bolt circle, and align the flanges carefully. It looks like you're okay.
11/14/2009 10:28 PM
Tapered inlet is not required? as received inlet is circular.
I checked by installing it between flanges it is ok , i think so. After fixing the bolts it will be fine.
tell me onething Flange is 8" 150 pound then why outer diameter is 280mm is there any calculation for that
11/14/2009 10:55 PM
Ideally, the outer diameter of the orifice plate should be at least as large as the o.d. of the raised faces (RF) of the mating flanges, but less than (bolt circle minus bolt diameter) of these flanges. This is not really a calculation, but rather a matter of looking up the values in a dimensional table. I will try to check further.
11/14/2009 11:05 PM
The orifice flanges are specified and procured in accordance with ASME B16.36, and per ASME code there is no orifice flanges with Class 150, where the 1st class is 300 as indicated in Table 1 Class 300 Orifice Flanges, Welding Neck, Slip-On and Threaded. From that table, the orifice flange with NPS 8, Class 300 has an OD of 15" (381 mm), and the flange shall be furnished with a raised face 0.06" (1.5 mm).
11/14/2009 11:13 PM
can you tell me when tapered inlet orifice is required and when circular inlet is required.
i mean to say....received orifice plate is a restriction orifice.
i saw most Flow orifices are having tapered inlet
pls tell me when tapered is required and why
this orifice plate is concentric square edged orifice
Good Answers: 68
11/15/2009 5:24 PM
Hi Guest,
Abdel Halim Galala, (hope I I have your name correct Abdel!) gave you the standards you should read.
It is not necessary to have a tapered hole orifice plate, if the plate is not flat, but has a taper on the hole/s on one side, the taper goes down-stream.
BTW the hole could also be tapered and circular! Just a case of definition!
But did you mean the plate has no taper on either face?
Just a thought, but if you read the code sent in by Abdel you will find all this out anyway. Good luck.
11/16/2009 11:11 PM
yes it is a concentric square edged orifice flate. it doesnt have any tapered in downstream side.
I asked you as, if there is no tapered then at downstream side turbulence will be more and this may cause damage in pipes wall day by day.
But our orifice is restriction orifice. Not measuring the flow but limiting the flow so that less flow goes to downstream.
if you know pls tell me, when tapered are required. in what condition tapered hole is required or it is related to construction features like concentric, ecentric and segmental.
thanks for your help Mr Abdel
Good Answers: 68
11/17/2009 3:44 PM
Hi Guest,
You can check out the codes and design factor by checking the Code standard set for this type of equipment as listed by Abdel on a previous post.
Whatever the reason for the restriction plate, there is no need for any tapered hole/s downstream. If the pipes are designed to allow the orifice place then they will be able to take any 'extra turbulence as you described.
There should be less overall pressure on the downstream section of pipe after the plate is fitted. Or perhaps I should say, after the plate is fitted the downstream pipe will be dealing with less flow so, the overall flow pressure should be less.
If you have a plate which is flat on both faces then that is fine and it does not matter which way round it goes. If there was tapered venturi then the tapered side must be downstream, OK?
Sometimes if not always, when using a tapered venturi plate there is an arrow near the edge to point to the downstream, but as your plate is flat this does not apply in your case.
Good luck.
Abdel Halim Galala (1); Anonymous Poster (3); babybear (2); Tornado (2)
