Previous in Forum: Watts and Electrical Connectors   Next in Forum: How do we detect Islanding of generator from mains without mains breaker status?
Power Measurements
11/16/2009 3:42 PM
Can mesuring required power (kw) for driving pump ,from mesuring electrical power parameters of cupleted motor ?
why? for proofing electrical consumption.
Re: Power Measurements
11/16/2009 5:53 PM
"Can mesuring required power (kw) for driving pump ,from mesuring electrical power parameters of cupleted motor ?" Yes
"why? for proofing electrical consumption." If the motors are the same you should get a close estimate of the kw usage.
11/17/2009 3:01 AM
The power required for any fluid mover is the volumetric flowrate multiplied by the pressure rise divided by the efficiency.
Good Answers: 170
11/17/2009 9:59 AM
Pump HP = {(Specific gravity of the fluid being pumped x Head x Flow rate)
/ (K x Efficiency of the pump)
The constant 'K' depnds upon the units of flow rate, head & specific gravity.
From this you can cross check the power required for doing the required pumping work. Divide this by the motor efficiency, that will give you the motor HP.
Good Answers: 50
11/18/2009 2:28 PM
The motor nameplate HP is its rated output mechanical power so there's no need to divide by motor efficiency, its already taken into account.
Just take the pump required power and select the motor accordingly.
Something new every day!
Register to Reply 4 comments
electricalexpert65 (1); MalcolmK (1); PWSlack (1); wareagle (1)
