Previous in Forum: neutral current   Next in Forum: Rotor Bars
Timing test on power circuit breakers...
11/17/2009 6:50 AM
What should be the next corrective measures if the power circuit breakers(SF6) had failed after testing of timing test??
Leader is YOU...
Pathfinder Tags: TIMING TEST
Re: Timing test on power circuit breakers...
11/17/2009 7:44 AM
hitxyker; return it to supplier. perry
11/20/2009 4:29 AM
Dear Hitxyker,
What is real diffrence in timing?
The failure of timing test is an indication of deterioration of some of the components.
You can try after the normal maintenance of the breaker as instructed in the O&M mannual.
Register to Reply 2 comments
You might be interested in: Circuit Breakers, Timing Screws
