Previous in Forum: Relationship PF with Maximum Power Output in Diesel Generator   Next in Forum: Timing test on power circuit breakers...
11 comments
neutral current
11/17/2009 5:33 AM
please let me know,what does it mean if the neutral current in a 3 Ph circuit is higher than the other 3 phases,,,as ex::R=17O A ,y=180 A ,B=175 A,,,,,but the neutral current is about 280 A !!!!?????does it mean that there is a leakage current or what??????
regards
Re: neutral current
11/17/2009 7:50 AM
needtoknow; is the neutral warm/hot to touch? are you reading harmonics? perry
Re: neutral current
11/18/2009 6:30 AM
perry;;;it is littel bit warm???is it risky ???
Re: neutral current
11/19/2009 3:14 AM
It is risky if the current exceeds the neutral conductor's carrying capacity. Is the neutral the same cross-sectional area as the other conductors?
Re: neutral current
11/23/2009 7:17 AM
pwslack
yes it is,the neutral cable cross section is the same as the three Ph's which is 4c*95mm2,and as i know this cross section can carry up to 270-280 A,so in order to avoid any problem i would decrease the load,,i thought that the un balance between the three Ph's doesn't mean this much less,,cause i think when we say un balance ;means more than -+(50)A between the 3Ph's
Re: neutral current
11/17/2009 8:05 AM
Is there a single phase generator connected to one of the three phases downstream of the measurement location?
Re: neutral current
11/18/2009 6:38 AM
pwslack;;no..there is no single phase generator connected to any phase...but i am getting the power to my 3 phase load from this 3 ph generator as usuall,and i am using a digital ammeter to cheack each phase current,but the neutral still higher than the 3 ph's .
Re: neutral current
11/22/2009 5:27 AM
In case any of the three phase load is a motor, it wouldn't have survived. In any other of the various typical 3 phase circuits also the single phasing is ruled out - (two phases connected at source).
Did you check up the voltage - phase-phase and phase to neutral? This would have given an insight to what is happening.
Good Answers: 170
Re: neutral current
11/17/2009 9:23 AM
It definitely implies presence of Triplen Harmonics in your system. Do undertake a Harmonic Study.
Re: neutral current
11/17/2009 11:13 AM
Oee have to doubt over the harmonics.......may be you have many nonlinear loads,switching devices n all..........
"Know something about everything and everything about something"
Re: neutral current
11/17/2009 7:11 PM
Multiple earthing also cause circulating current ,if your system has multiple neutral grounding
Re: neutral current
11/17/2009 8:26 PM
Check the voltage between phases. If you happen to have two of the phases connected together at the source you would get neutral reading as you are showing.
Register to Reply 11 comments
Anonymous Poster (1); electricalexpert65 (1); giri (1); JOSHIKD (1); needtoknow (3); perry (1); PWSlack (2); wareagle (1)
