Previous in Forum: Timing test on power circuit breakers...   Next in Forum: Distance Protection
Rotor Bars
11/17/2009 7:51 AM
Hi
How can I know the number of rotor bar ? Because I can not find any information from its specifiation.Is there any relation with other electrical spec of motor?
Pathfinder Tags: rotor bars
Re: rotor bars
11/17/2009 8:03 AM
I don't have a clue.
Maybe this will help, maybe not.
http://www.reliance.com/mtr/pcrssmn.htm
Re: Rotor Bars
11/17/2009 8:46 PM
I only know two ways - count them or ask the OEM.
Re: Rotor Bars
11/18/2009 12:14 AM
One way to count them, or at least to verify the OEM's advice, is vibration analysis of the motor under load. On a high resolution 0 - 10kHz acceleration spectrum, you'll usually see an isolated spectral peak at a frequency corresponding with (motor turning speed) x (rotor bar count), and/or another one at (motor turning speed) x (stator slot count). But if the motor is in poor condition you may also see sidebands around either of those peaks that make them hard to pick.
Re: Rotor Bars
11/24/2009 7:47 AM
If u are a motor designer you will know it when you finish the design.otherwiseyou need not.
Re: Rotor Bars
11/25/2009 6:10 AM
Thanks a lot professor.I ask this question because I want to know numbers of them for CM software for analysis vibration.
Re: Rotor Bars
11/25/2009 7:46 AM
Thanks.No Problem.You can write to the manufacturer with specific machine sl no and he can give it .This will be subject to thir policy.
Register to Reply 6 comments
Anonymous Poster (1); bipc54 (1); bkar (1); lyn (1); nesubra (2)
