Previous in Forum: turbocharger   Next in Forum: Pneumatics or Hydraulics?
Solar gas Turbine T-4002
01/10/2007 6:42 AM
Exhaust temp. is high during start up and turbine get tripped on Tmax.
Re: Solar gas Turbine T-4002
01/10/2007 7:45 AM
Really?
That's fascinating.... So what is the question?
Good Answers: 19
01/11/2007 4:02 PM
Yes what's the question?
Check your Radiator it is not compatable to your environment-condition. In hot countries the standard radiators from the colder countries may not be compatible.
02/05/2007 8:14 AM
If you're talking about a gas turbine engine, it's normal that during startup your EGT is high, due to low air flow.
What do you mean with turbine get tripped on Tmax? Aren't you talking about an instrument? Give us details and a clear question.
Humm... suspicious you are...
bhrescobar (1); ducon (1); Electroman (1)
